Depending on the size of your head you may need a adult helmet. As for cooling looks like the 06 Pro Bravo helmet has the best venting.MTB-AHOLIC said:
Depending on the size of your head you may need a adult helmet. As for cooling looks like the 06 Pro Bravo helmet has the best venting.MTB-AHOLIC said:hi all, i am trying to choose between 2 helmets, that are both six six one. The Hurricane flight youth and the launch youth. which one? I dont know wich is heavier which is the main thing Im concerned about. I know that full faces are hot but I also want to know wich is cooler because I live in Georgia and its hot as hell down here in the summer. Also should i even get the youth? I am 14 years old. Your help is greatly apreciated. thaks.
Full Bravos...no problem...i rode XC in Georgia (Olympic horsetrails) in one this last August...wasn't bad at alldogonfr said:Depending on the size of your head you may need a adult helmet. As for cooling looks like the 06 Pro Bravo helmet has the best venting.
I ride a Deviant and like it. I can use it for basically everything. The difference between the Hurricane Flight versus all your other helmet choices is that its a Moto Helmet so it is Dot/Snell approved. Although it appears to have some decent intake near the mouth, there are no vents to just let your head cool off...MtN BkR90 said:look at the specialized deviant. very light and tons of vents. it keeps me kool when it is hot out.
So true. My 661 Full Bravo fit nice when I pulled it out of the box, but after the padding conformed to my face and broke-in a little, it fit's too loose. I ordered mine online and already had it out on a couple of rides before the looseness showed up, so now I'm stuck with it.shiggy said:You must try them on. Every helmet fits differently.
I second the vamoose II, light, breaths well and they have a bunch of sizes to choose from rather than just sm, med and large. Good for the between sizes head.MVRIDER said:Every helmet will fit slightly differently, If you dont have a chance to try one on before buying it, make sure to check the mfgrs. sizing charts, and follow them!! I don't want to sound like a total whore here but so far I'm loving my Vigor Vamoose II carbon...you may want to check them out.
