10
Price: 5300$ (firm)
Reason for selling, I also have a '21 Commencal Meta TR in Large which is my primary bike and wanted this one as my secondary play bike. I'm 6 foot tall (fairly long torso)l and just can't get comfortable with the Mojo 4 from a reach perspective ( feels quite cramped for me even though it has 485mm of reach on paper). Maybe I should have gotten an XL? Built this for somebody my size and weight - so the fork and rear shock is quite burly (the front fork have 37mm stanchions, and the rear shock only needs 170 PSI of pressure to hit the proper sag for somebody 210-215 lbs). Also has the stopping power to match.
Specs:
- Ibis Mojo 4 - Large - Blue
- Shimano 12-Speed SLX Drive Train (Crank, Rear Derailleur, Cassette)
- SLX Rear Derailleur Upgraded with XT Ball Bearing Pulleys
- Shimano Dropper Post Lever (SL-MT500-IL) - ISPECEV
- XT12-Speed Shifter (SL-M8100-IR) - ISPECEV
- Shimano Deore Brakes (BL-M6100) w/ 4 Piston Calipers (BR-M6120) - modified to use PIN AND CLIP (just like the SLX,XT, and XTR)) instead of COTTER PIN for easier brake pad replacements.
- Jagwire 203mm Brake Rotors (Front and Rear)
- IBIS ISCG 05 Mount w/ Funn ZIPP Bash Guard
- Manitou Mezer Expert (for 27.5 Wheels - 37mm Offset, 37mm stanchions) upgraded with IRT (Infinite Rate Tune)
- Manitou Mara Rear Shock
- PNW Range V3 Handlebar
- Origin 8 55mm Stem
- OneUp V2 Dropper Post - 210mm
- Ergon SMC Saddle (Large)
- Ergon GA2 Fat Grip
- Cane Creek 40 Series Headset
Custom Built Wheel set
- DT Swiss EX511 Rims
- DT Swiss Squorx Pro Nipples
- DT Swiss Centerlock to 6-bolt Adapters
- Pillar PSR Aero 1423 Spokes
- Maxxis Assegai Tires in the Front, Maxxis Agressor in the Rear
- Nukeproof (ARD) Advanced Rim Defense Tire Inserts
- ZTTO M1 Straight Pull hubs / Star Ratchet / with DT Swiss Parts (Ratchet Springs, Ring Nut, Bushing)
- DT Swiss Bearings on the Front
- Japanese Bearings on the rear (IJK, NSK)
