1 - 2 of 2 Posts
Discussion Starter #1
Are you looking for a plusher ride on your 2016 and up Fox Float 34?
For sale is a luftkappe piston installed on a current generation 140 evol airshaft.
This is a direct air shaft swap for 2016 and up 34 float forks.
Included in the sale is the piston on the shaft as assembled, plus roll pin tool, plus original evol shaft parts (piston and bump stops.)
This solves for known top stroke harshness on 2016 and up 34 forks. The setup has low hours and is very much in like new condition. I've since gone with a different setup so putting this up for sale.
Asking $180 for everything as described. Shipping at buyers expense.
I can remove the piston form the airshaft as well.
Thanks for checking out the posting.
I have a 2017 Fox 34 Performance 130 mm fork (with FIT, if that makes a difference). I am thinking of upgrading my airshaft to 140, which will only cost $30. The fork came in standard with the Trek Fuel EX bike.
So just to clarify, you are selling the Luftkappe piston, plus the 140mm airshaft? Is that correct? Will this fit my fork?
1 - 2 of 2 Posts
