1 - 1 of 1 Posts
· Registered
Bicycle Bicycles--Equipment and supplies Wheel Tire Bicycle wheel rim
Large 2014 Trek Remedy 9 29 with upgrades / updates
Asking $1900 firmish would prefer to deal locally + shipping In Flagstaff, Az
140mm X 140mm Travel Geometry is good compromise pedals uphill well
This fit me well and I am a somewhat ape like 5'11'' with long arms and inseam
Chain stays are a slight upgrade from newer 2015 bike and have better hardware
Bearings are all in decent shape
Front triangle has a quarter size dent in the down tube
This bike is not perfect cosmetically with typical scratches dents paint chips stuck on mud, but all is functional and its well spec'ed.
No stock garbage parts that only lasts 2 rides left on this thing - its all solid parts
FOX CTD Shock from 2015 bike with DRCV and upgraded thru shaft reaktive damper
Fork Fox 34 Kashima coat FIT4 CTD - this needs a full rebuild
Seatpost PNW Rainer IR 170mm drop With Loam Lever - This thing is nice
Brakes Shimano XT with new 4 piston SLX caliper front and 2 piston XT rear. 180 Rotor front 160 rear XT. Metal Pads still got some life
Drivetrain Shimano 1 X 11 Wide range Not old fashioned stock 2 X 10 XT
Xt crank with 32T one up narrow wide chain ring, Deore 11-51 wide range cassette and of course XT shifter for multi release goodness. This is all fairly fresh
The bottom bracket creeks because its a press fit - bearings are good and its anodized red wheels manufacturing
Race Face Affect Stem and bars 35mm 760mm. Lol so you dont have to cut down an 820 bar. Generic lock on grips with deighty knock off design
Stock bontrager saddle
Wheels DT swiss 350 rear hub 32 hole Spank Oozy trail 295 rims generic BHS front hub 28 hole These are great wheels not to light not heavy, reliable.
Theses are 100 x 15 and 12x 142 axles
Maxxis DHF 2.5" / DHRII 2.3"tires DC/Exo About 1/2 to 1/3 tread left. Tubeless of course
Will include a second OE shock with blown drcv transfer valve and needle bearing that is missing parts
Will include a spare Rear Derailleur hanger
No stinkin pedals included
Bicycle Tire Wheel Bicycles--Equipment and supplies Bicycle wheel rim
Bicycle Wheel Tire Bicycles--Equipment and supplies Crankset
Bicycle tire Plant Bicycle fork Bicycle handlebar Bicycle frame
Bicycle Bicycle frame Bicycle handlebar Bicycle tire Bicycle fork
1 - 1 of 1 Posts
