Figured I'd cross post this here since there is more action.
http://forums.mtbr.com/showthread.php?t=583779
Sooner than later I plan on running a FAT Front w/PUG Fork and using a Large Marge/Larry Combo.dubthang said:Do you feel that you could go wider than the Gordo, and still have a great handling bike up front?
I tried out a fat Carver last summer. The thing was awesome, but the tires (Endos) go with the rims. I'm trying to figure out if there is a line where rim width becomes to great for the currently available 29er tires out there. Would a KH 47mm render a 2.4 to 'square' to have good traction up front?PanFry said:Sooner than later I plan on running a FAT Front w/PUG Fork and using a Large Marge/Larry Combo.
Might be pretty heavy but I don't really care.
PF
I could absolutely get away with using a KH Rim and my WTB Kodiak. Should work out great. But, if I were to go wider it would be all the way with the Large Marge 26"/3.8 Larry. I wouldn't see the point in using a KH if I already own a GORDO. For a 29" wheel the GORDO is as wide/heavy as I am willing to go.dubthang said:I tried out a fat Carver last summer. The thing was awesome, but the tires (Endos) go with the rims. I'm trying to figure out if there is a line where rim width becomes to great for the currently available 29er tires out there. Would a KH 47mm render a 2.4 to 'square' to have good traction up front?
Do you feel that you could get away with a wider front rim, and still get positive results on your current setup?
Do you have the trials 47mm or the xc 38mm?CaveGiant said:I ride the KH and it is amazing, it squares off every tyre I have put on it.
Stout and Weirwolf are faves.
The squared tyre gets more tread down, so much more traction, and is more stable.
best upgrade ever.
Do you ever see motorcycles with 19mm rims? Bigger tires work better on bigger rims.richwolf said:Do you ever see motorcycles with square tires that handle worth a dang?
Do you ever see motorcycles with square tires?cutthroat said:Do you ever see motorcycles with 19mm rims? Bigger tires work better on bigger rims.
I asked because I was trying to find out the max width one could go with the front rim before it adversely affects handling.CaveGiant said:I have the FR on the front and XC on the back.
Why do you ask?
P
