1 - 3 of 3 Posts
Freshly Fujified
Adjustment needed
From the sounds of things, the rotor is rubbing against the pads inside the caliper. This could be one of a few of things. First, it could mean that the front wheel is misaligned. Undo the quick release skewer and reset the wheel, then tighten back up. Second, it could be that the pads need adjusting. Third, it could mean that the brake caliper itself needs to be realigned. If it's the second or third issue, consult with the owners manual or Ibex for guidance on making these adjustments.
Bob
1 - 3 of 3 Posts
