I have a hard time envisioning the scenario you're trying to describe beyond the fact that there are lots of roots. They're rubbed smooth from traffic. Some poke up a good bit. And sometimes there are turns.
The way it reads to me, is that you need to work on your technique. Turning on smooth roots (esp when wet) is treacherous at best. Your line selection needs to be dialed and your skills strong enough to hit exactly in the right spot to minimize the chances of sliding out. You need to utilize a lot of upper body weight shifts to keep your tires lightly weighted in spots with poor traction. You don't want to slide out sideways up front, but you also don't want a sudden spin-out in the back. You're going to need a full toolbox of front wheel lifts. There are several different types that all involve different body movements to make them happen. And they're useful in different scenarios. Just because your front wheel is in the air doesn't mean you've done a manual. A manual is only one specific way to get your front wheel up. If the roots are nasty enough, you might even need some trialsy hopping skills to be able to change your position in the roots without having problems with your tires sliding.
There may be some equipment things you can address, but it's definitely not primarily equipment. It's primarily skill.
Equipment things that might help:
*Tire pressure adjustments. If your tires deform/flex around the roots, you'll have better traction when riding over them. I won't say "good" traction, because that'll never happen. But "good enough" might if you combine riding skills.
*Larger volume tires. The more volume your tires have, the more capacity they have to flex around roots/rocks. There is a relationship between tire size and tire pressure, as well. Bigger tires will take lower pressures.
*Soft rubber compound on your tires. The softer the compound, the better they will grip smooth/slippery stuff.
*Suspension settings. Especially if you're trying to ride through this stuff at speed, suspension settings (adjusting what you have for your body weight and riding conditions) will play a role. Less so replacing the fork altogether, unless the old one lacked the ability to adjust it.
