1 - 8 of 8 Posts
Hi,
I'm looking to pick up a pair of second hand forks off craigslist to put on an older bike for a rider about 120lbs.
Their current forks are a pair of marzocchi exr from 2003 and don't have any travel for them at all. From what I've read they have springs and so aren't adjustable :(
Are there any things I should look out for when buying a new pair that would make them better suited to, or adjustable for, a lighter rider. Any particular models that would be good?
I know it's best just to buy a new bike, but the person can't afford one right now and they are passionate about riding trails.
Thanks for any assistance.
Cheers
Try and find an older pair of SIDs. They are air sprung so adjustable for lighter riders and although they are a little flexy compared to the new SIDs and REBAs this will probably not be such a big deal for a lighter rider. If you look you can get them surprisingly cheaply and they are not a bad fork, fairly tunable and light.
wuss
Air shocks are more easily adjustable to lighter riders, but have more friction due to having extra seals in the air spring.
If you can find a suitably light spring for a coil fork you might end up with something far smoother, but also heavier (especially as all the lightest xc forks are purely air forks to save weight).
Former Bike Wrench
I would recommend a dual air fork (such as the SID) as many air and coil forks use a set negative spring that can often be too heavy (thus causes too much sag with the correct spring rate) for light riders.
Older SID's are a great lightweight rider fork as they are very light, very tunable (lighter oil in the damper for a lighter rider), and use an adjustable air negative spring.
1 - 8 of 8 Posts
