mtnbiker72 said:
A 10mm difference in travel (140mm vs 130mm) will result in less than 1/2 of a degree steepening of the headtube and seattube angles. It is highly unlikely that you would even notice the difference.
Lets use our brains here people :madman:
ok let's
The difference in travel of the two forks, marzocchi drop-off and rs pike is 10mm. The actual total crown height of the pike is in fact 20mm shorter because it is more compact than the notoriously tall crowned marzocchi fork. This means 10mm from travel and 10mm from crown/fork design. 20mm is 2 centimeters and yes steepening your bike a full degree actually is noticeable, I've ridden the bike both ways.
I like riding the Pike better because my fork doesn't wander as much from the added weight on the front. Some people put longer forks on it and that's probably noticeable too, but for better or worse that's their decision.
If you want me to find the crown height of the tora it's not difficult, but a rough geuss would be that it's ~30mm shorter than the stock drop-off. Again, this is because the marzocchi has 20mm more travel and a taller crown than the rockshox
hope that makes sense
and oh yea, I still think the dawg is the way to go if you're running a tora fork
EDIT:
http://www.marzocchi.com/Template/l...LN=UK&Sito=usa-mtb&IDFolder=229&Submit=Select
via this, the 06 OEM Drop-Off 4 is 539.7mm axle-to-crown length
http://www.sram.com/_media/techdocs/Tora US4-310058-010_A.pdf
via this, the axle-to-crown of the tora is 509mm
well, 539.7 - 509 = 31.7, so if you slap a tora on the coiler you'll be putting a fork that's almost 3.2 cm or 1 1/4 in shorter
For front/rear suspension balance, that'll be a little off, but in terms of use and durability, the coiler frame is meant for a bit "beefier" fork.
hope that helps
