thinking about a fat tire bike. did some searching today on the frames and forks. looks like 2 main ways to go, offset and non-offset.
it looks like for the rear if you go offset you'd use a 135 mm rear hub. non-offset you're looking at a 160 mm rear hub.
for the fork, offset you use a 135 mm hub. from what i found there's only what, 2 front hubs out in 135 mm spacing? Surly and Phil Wood? or is it Paul Components? unless you just use a 135 mm rear hub.
do i have this somewhat correct? living in nw wa state, thinking about a mud bike. on the cheap.
monte
monte
