1 - 4 of 4 Posts
Ok, something I've never dealt with here. I've got an 08 Stumpy Expert with a Fox F32 120mm fork. I'm looking at upgrading the fork and going to a 140mm, but most of these new forks are now 15mm thru axle. Can I simply replace my front hub with a 15mm design without doing anything else to the wheel? If not, what else is involved?
From Specialized: Specialized Hi Lo disc, 28h CNC flange and disc mount, sealed cartridge bearing, 9mm DT RWS alloy QR
I am also looking for a used fork, there is a chance that I could end up finding one with a 20mm thru axle...so should I get a hub that has the capability to go from 15-20mm?
Finally, what hubs to stay AWAY from?
thx for the help on a new subject for me.
BQ
Premium Member
BQ
Your hub might be convertible to 15mm.
If not, you need a new hub. The spokes will need to be replaced, too. Better to get a whole new wheel than reuse your present rim.
Not a bad idea to get a hub that can be converted to all axle types, such as the Hope Pro II or DT Swiss 240 Oversize.
Will a DT Swiss 240 Oversize at 110 mm wide, convert to a 100 mm wide size for QR or 15 mm axles?
1 - 4 of 4 Posts
