I am in the process of building a reign for my buddy cyfer, I should have all the parts and the frame by this friday. We decided to get the Marzocchi AM II 130/150 fork with eta adjustment. You can crank the fork down as low as 30mm for a hill climb and then set it at either 130 or 150mm of travel. Down shift cycles has it for $365 on sale, normally $505. I purchased another marzocchi fork from them last year and they have the best prices around! I originally spotted them on ebay and you can go to their website and also get bargains. The owner Jared is a cool guy, will give you a great deal! Shipping is also free!
On your splice, do you have through axles or standard skewers? The Fork I mentioned a standard skewer and not a 20mm through axle.
http://downshiftcycles.sslpowered.c...t_info&osCsid=52a5d67506b2f44372eba2f72bb0790
http://www.marzocchi.com/Template/d...QG#[email protected]#793,&mCJ=&IDOggetto=28060
The Marzocchi All Mountain is truly built for the entire mountain. Climbing is a joy and descending is pure bliss. At a mere 5 pounds, the All Mountain 1 is one of the lightest long travel single crown forks on the mountain. It is fully adjustable from initial setup to on-the-fly trail tuning. Marzocchi delivers the entire package for your all mountain needs.
DAMPING SYSTEM New SSV System
Open Bath Lubrication
ADJUSTABILITY External Air Preload w/o Adapter
Single Rebound Adjuster
ETA + TAS 130 > 150mm
SPRING TYPE Air
Long Negative Coil Spring
TRAVEL 130mm to 150mm Travel
TOP CROWN N/A
LOWER CROWN New Forged Crown Specific for All Mountain Use
ARCH/SLIDERS New All Mountain Magnesium Monolite
STANCHIONS
(inner legs) ø32mm Alloy Black Stanchions
STEER TUBE Alloy FR Steer Tube
DISC BRAKE MOUNT Disc Brake Post Mount
DROP-OUT TYPE Standard Drop-Outs
OPTIONAL FEATURE New AM Integrated Fender
FORK COLORS Flat black
DECALS COLORS White/Red
