Hey everyone,
I have a Trek (can't remember the model) that my brother just gave to me. I have to change the crank set on it. Where you screw in the pedal to the arm is stripped. I actually have another crank set at home that I can use. But when I put it on, the crank teeth hits the bracket that the derailleur is mounted to.
This derailleur bracket is attached to the bottom bracket. So I took the bracket off and was going to put a post mounted derailleur on, but I am unsure if it will work.
Any thoughts?
Thanks in advance,
Kevin
Any thoughts?
Thanks in advance,
Kevin
