1 - 4 of 4 Posts
YOU SCRATHED MY BIKE!!!!
i went riding today at Amelia my bike performed very good again but when i got home i started cleaning it and the chain is constantly rubbing the front derailleur no matter what gear combination but it doesn't look bent so i have no clue why its doing that?
~Disc~Golf~
which side?
adjust barrel adjuster to move the cage in the appropriate direction.
(I'm just guessing, but I'll say it's rubbing on the inside and you need to add tension - $10 :ihih:)
I'm guessing that the FD got slightly turned. If it was cable tension I would think at least some of the gears wouldn't rub the cage if the limit screws were set correctly.
Carlos, make sure the FD cage is parallel with the chain rings. If not, make a trip to the LBS for them to align it.
1 - 4 of 4 Posts
