You’re derailleur could be getting corroded within the pivots. I had a similar problem a few months ago. I took it to a shop and the mechanic degreased it in a washer. The derailleur improved but the cage later broke. It was an old derailleur. The silver lining was buying a new side-swing, which is a substantial improvement.
You can try replacing the housing too. Grime will make its way into the housing over time, especially bottom pulls.
