1 - 4 of 4 Posts
Picture Unrelated
Which side is it rubbing on (inside or outside) and what gear in the rear is it in when you are having issues?
With it on the big ring (front). See if you can pull the front der. outward with your hand. If it's all the way against the limit screw, you won't be able to move it. Turn the outer limit screw counter-clockwise some. You still may have to adjust the cable if it still rubs.
If it's not against the limit screw (you can move it outwards with your hand before it stops), you need to adjust the cable by turning the barrel adjuster at the shifter counter-clockwise until it doesn't rub. Then check that the indexing works for the other rings.
1 - 4 of 4 Posts
