1 - 4 of 4 Posts
I bought this bike set up as a 1x10 but have decided to go back to 2x10 and am having trouble routing the cable back through the frame.
Any tips or tricks. Thanks.
Also, does anyone know if the the regular double chain ring set up takes a different chain ring bolt than the RF n/w single? The bolts that were on the n/w are too long. They tighten down against the other side of the chain ring bolt before the ring is tight.
ups and downs
Yes the RF NW chainring bolt setup is specific to that chainring, the 2x and 3x bolts are the same length.
The easiest way to route an FD cable through the frame is by removing the frame plug at the bottom bracket. You can play around with some cable liner and inner cable, but unless you're very lucky it will be faster to pull the plug out.
1 - 4 of 4 Posts
