Can someone explain to me how the offset on front derailleur direct mount adapters is measured? I think I have the wrong offset but don't understand how they are measured.
I picked up a 9:zero:7 Tundra. I finally got a SRAM GX 2x10 high direct mount, top pull derailleur. My LBS sent me home with an Origin8 100mm BB adapter. I'm running the same cranks that were on my previous bike with 197 rear. When I mounted up the adapter and derailleur I can't get it to swing out far enough to hit the big ring. I backed off the limit screw all the way and it still won't swing out far enough. The Origin8 adapter said online it's 85mm spaced. Problem Solvers are 39.5mm (3x), 43.5mm (2x), Moonlander (unspecified), and Wofltooth/Borealis is 50mm. I thought it was from the outside of the seat tube but then the Origin8 at 85mm didn't work with the math.
