I've searched the threads enough and found some good posts from 4 years ago on choosing a light front derailleur for a 2 x 9 set up. I just got a new Niner JET 9 XL size frame and need to get a lighter derailleur.
Now, for the moment, remove the irony of building a weight weenie 29"er full suspension bike.
My idea of weight weenie success will be if I end up in the 22.x - 24.x lb range. On paper I'm there, but that's on paper. And keep in mind this is a size XL full suspension XC race bike in the 29"er wheel size.
Back to the derailleur...
Niner recommends the XT M771 in 34.9 clamp, bottom pull, bottom swing (traditional) due to some clearance issues, blah, blah, blah. Again, I'll be running 2 x 9 with 27T/40T rings on 180mm Race Face Turbines - square taper so I can really dial in my chainline and Q-factor.
I've got the Shimano XT M761 traditional in dual pull that I was running on my Sugar, but it is a porky pig at 178g!!! The question is, and I believe Nino raised this issue back in a thread I just read from 2004, can one run a Dura Ace double on a full suspension frame? Would a triple be better?
As you can see in the photographs, the swing arm and clearance issues noted by Niner. The new XT M771 is a design that takes clearance issues into account:
Increased tire clearance through modified cage tail shape. More clearance behind the seat tube for down swing FD, mud guard, or suspension. With front SIS, Dual Pull, Multi Clamp Band, and Offset Adjust Bolt.
But before I hit the buy button, I just wanted to think it through to see if there are other, lighter options. XTR, Dura Ace, etc...
Here's a shot of my porky pig M761 mounted on the frame with an example of a 2 x 9 crank (not the one I'll be running, but one from my parts bin):
(cable is not hooked up, so the cage is sitting way in in the "limp" position)
Another angle...
Profile...
It sounds like the latest XT mountain FD's would save me 20 - 40g over my older XT, but if I'm going to buy a new derailleur I might as well shed some more. That's why I am wondering about the Dura Ace. I'll be running a SRAM Twist to trim the front derailleur for the best shifting.
Any suggestions on a 34.9 clamp, bottom pull, bottom swing light derailleur that would work on this JET 9?
Thanks.
Another angle...
Profile...
Thanks.
