1 - 6 of 6 Posts
Reviewer/Tester
I have been thinking about going to an 8" disc on the front of my VT-2 for a few months.
Are there 'kits' available to do this, or, what would I need to do this conversion, and where can I buy it?
The current brakes on the bike are standard Hayes nines.
Thanks..
R.
what you need is ...
A new rotor and a caliper adapter... probably cost $60 total. Hope, EBC etc make both, not sure about Hayes. Watch out for warranty issues on your fork. Other than that, brilliant. Apparently, the math determines it gives you about 40% extra stopping power, which seems loads but it simply turns good brakes into brilliant brakes and, despite what some people say, its not over-kill for XC/trail unless you're racing.
mtbr "member"
Definitely 8 inches...
Rainman said:
Thanks for the info.. I'll chase it up. :)
R.
Been a big proponent of 8 inch front rotors since way back when I had a Marzocchi Z1 alloy in 98. Hayes used to make a adapter for the fork's funky tab spacing but only had an 8 inch rotor option - no 6 inch AT ALL. I was really pissed at first. Then after riding a season, I converted all of my bikes to 8 inch font and 6 inch rear, and have done so ever since. Never had a problem with QR's or disc tab failures on various brands of forks but I mostly stick with Marzocchi and White Bros.
Check out Universalcycles.com for cheap Avid adapters. They run about $9. And don't worry they'll work with Hayes systems. I have a mix of Avid and Hayes adapters on my bikes, no problems. Hayes 8 inch adapters for QR forks are REALLY hard to find or are expensive.
REEK
1 - 6 of 6 Posts
