As comparison my titanium rings which have longer lifespan.
You have to add spacers when converting triple cranksets to double using the inner two positions to get the correct distance between inner and "middle" ring. Without spacers the chain might fall between chainrings when shifting.Ninko said:Those rings look great, I'm looking for the 42T. Do you know where I can buy them and why should you add those red spacers?
I had to use spacers on my RaceFace cranks.But maybe that's just because of Mattais rings beeing thinner than "normal" rings? Anyway - most guys i know need such spacers otherwise the chain will fall between the chainrings when shifting.Ninko said:That was what I was thinking! The chainring is in the right position. Only your chainbolts are to long so the red spacers act like a normal chainring so you can use normal bolts... That's it! You don't have to fit them in between the ring and spider!
