might be time for a seal change if you are running the stock seals from 2006. cold temps will stiffen/harden rubber products
Well, one hour of riding on the hitch rack should be enough i suppose! It happens a little while into the ride as mentioned by heckhazz. He also mentioned that it happened with reasonably new seals, so.. looks like it's a glitch i'll have to live with. :madman:Brown_Teeth said:Freezing will shrink seals no doubt especially if you are taking the bike from warm to cold conditions, the seals will cool faster than the rest of the fork due to exposure and use. Might be best to make sure your bike is cooled off to ambient temps before riding. Give it a try. I can't help you on the experiment since its 65 and sunny in CA today![]()
Frost can form on the stachions in certain conditions, if this happens a rubbe seal can wear out pretty quickly, and water can get into the fork, etc...PsyCro said:Well, one hour of riding on the hitch rack should be enough i suppose! It happens a little while into the ride as mentioned by heckhazz. He also mentioned that it happened with reasonably new seals, so.. looks like it's a glitch i'll have to live with. :madman:
Heck, Jayem says even enduro's do the same thing (granted, 1 year old).
Hopefully just adding air pressure once during the ride will be enough.. a little oil shouldn't hurt though.
Marz .. India .. 2006 ..Turveyd said:06 was a bad year for Marz to when they moved to India or something and the Quality dropped through the floor sadly![]()
Marzocchi seals seal better than any other seals out there; for those with Fox and Rock Shox seals who have experience only this approach to sealing; Marzocchi uses what you could call a 2 stage seal; the visible part is a dust wiper, which is followed by a separate oil seal.PsyCro said:Marz .. India .. 2006 ..![]()
Not only on the xc forks.. on the FR forks as well!! They NEED to put it back into the 66 (might as well put it in the 55 as well then) IMHO. After all, FR usually means pedalling to the top.Bikesair said:If they bring ETA back to the XC lineup I think they would have have something a lot of riders would want.
Let me get this strait, you're saying the Enduros were better than your stock Fox seals and that you can't detect any difference between the Enduros and the OEM marzocchi seals?Bikesair said:Ya IDK why Jayem has had so much trouble with his Enduros but everyone else is adiment that they are better than OEM...including me.
I would call Chris at Enduro seals and ask him how cold weather effects his performance. He does constant testing with durometers and tolerances for these exact issues so I am sure he could shed some light on the situation.
When I installed my NEW Enduro seals on my Floats it was obviouse that my small bumb compliance was better...maybe just because of the new lubricants though. The point is I didn't have to 'break them in' like the old Enduro seals. I don't have years of ride time on them yet but after 10 rides or so...not a drop of oil.
I also put them in my Junior-T's but the original seals worked fine. My Marzocchi seals have always been pretty dang nice. My 09 888 seals havn't wept a drop.
Not quite, although the tunability aspect of it is pretty cool, the prior dampers were extremely crude in function and the Evo uses an actual shim-stack with a needle-valve for low-speed. The old RC3 wasn't really much different than the old HSCV/SSV cartridge dampers from back in 1998, the base-valve was pretty much the same, and the "compression adjustment" that came out with RC2 and 3 simply made the fork harsher and didn't really adjust low-speed compression to give you any usefull adjustment. Now, the base-valve evidently has a real shim-stack (older ones did have the shims, but not really "stacked" for high speed control) and real low-speed compression adjustment.Bikesair said:They introduced the new Evo damper for the people who think they can make a shim stack.
06 was made in Italy as well.Turveyd said:They moved the place they make them to somewhere cheaper, I had 06 MX Comp's and AM2's both rubbish!!
My first Marz forks aswell, typical 05's and before where good and lasted well.
