it was called "drews adapter" I had one on my fixie for awhile
I have been running a Surly Fixxer on a Spinergy Spox wheel on my single speed since 2003 with no problems, and on a Spinergy Rev-X wheel on my fixed gear since 2005, no problems, well actually on my fixie the mounting splines have started to open up a little bit and I get a slight rock when I go from pedaling to skidding, nothing big but it is going strong still.GTscoob said:Surly makes one called the Fixxer but they dont recommend its use on SS applications. I dont know why not since I'd think fixed gear would provide the most stress but if I had to guess it would probably be so that park and DJ kids wouldnt try to use it and then complain when they broke their freehubs.
to go fixed with the drew's adapter you have to use an old BB lockring, but you can go fixed on the Surly fixxer no problemRobertUI said:I'll be watching this, as I'm hoping to do the exact same thing on my commuter, which is now a ss, but I really wanna go fixed on it!
Bit confusing, but like scooter pointed out there are two entirely different things being discussed here. What kind of hub do you have?RobertUI said:I'll be watching this, as I'm hoping to do the exact same thing on my commuter, which is now a ss, but I really wanna go fixed on it!
Correct, the Drews adapter moves the freewheel threads about an inch farther out for proper chain lineboomn said:Bit confusing, but like scooter pointed out there are two entirely different things being discussed here.
The Surly Fixxer converts Shimano cassette hubs into fixed gear hubs
The "drews adapter" that the OP asked about converts a geared freewheel hub into a properly spaced singlespeed freewheel hub IIRC
So I'm guessing there are a whole bunch still out there jb-welded to a fixie cog and sitting in the dump?peanutbutter said:Drew's Adapter works for singlespeeds, but for fixed you'd be asking for trouble, bb lockring or not...
i was looking for one a while back and they are super hard to find now. they didn't last long as they were marketed for fixed gear but worked terribly for it, as there was no way to put a lockring on the adapter itself.
good luck! if you find one and there are more let us know, i could still use one!
The Drew's Adapters run about $50 and redishing can cost you nothing but learning a new skill if you don't already know what your doing..1 cog frog said:That's the one, now to see if I can find another one!
frog
That's what I said. I used the term "freewheel" both times, and "freewheel" is only used to describe the screw-on kindDiDaDunlop said:"The "drews adapter" that the OP asked about converts a geared freewheel hub into a properly spaced singlespeed freewheel hub IIRC. I guess it works for fixed too."
No, it converts a SCREW ON multispeed freewheel hub to a SCREW ON singlespeed freewheel hub.
He had it correct too; he asked the question!DiDaDunlop said:"freewheel hub designed for 5-6-7 speed freewheels"
That's your old skool SCREW ON freewheel hub and not the splined cassette freewheel hub that has the freewheel system in the hub.
scooter916 said:to go fixed with the drew's adapter you have to use an old BB lockring, but you can go fixed on the Surly fixxer no problem
