1 - 2 of 2 Posts
Took apart my XT disc hub last night and my freehub and drive side bearings are shot. There is major pitting in the freehub cup and the bearings were actually deteriorating! My question is...can I use any Shimano freehub as a replacement? Also, what size bearings will I need? Best place to buy? Thanks so much for the help...
T
T
Some Shimano freehub bodies have different diameter dust caps which can cause some compatability problems with the RH axel dust cap
If you don't want to speed the $$ for a XT you can certainly put on a LX freehub or even a Deore.
You will need 1/4 bearings for the rear - clean and inspect your cones before putting it all together
Best place to buy - LBS.... bring in your old X spd freehub and get them to order the correct one
1 - 2 of 2 Posts
