1 - 4 of 4 Posts
AllMountain+CwmcarnUplift
Discussion Starter #1
1st question, is the freehub the ratchet inside the hub that lets you pedal/freewheel?
2nd Ive got a Sun ringle Jumping Flea Hub and the freehub/ratchet is broken do i need a new hub or can i replace parts?
3rd if you can fix it how easy is it to fix or should i just take it to my LBS?
cheers D.
local trails rider
Depends on what exactly is broken. Is the freehub body broken or just the pawls and springs? Then you'd need to know how to remove and install the body.
1 - 4 of 4 Posts
