Ok, these are my notes on AM1 oil change. It's a compilation from various responses from the Shock Forum, many from SSINGA. I don't know if the instructions work for other Zoke models, I know the oil volume is not the same accross the board.
AM1 Oil Change Instruction ---- Marzochhi 661-257-6630
Tools: 21mm socket, tapered thin-wall 12mm socket(optional), 2.5mm allen key Straw to measure oil level, cloth pin to hold straw on crown (height method). Measuring/oil pouring device in cc or ml such as a beaker or syringe.
7.5 weight Golden Spectro or Marzocchi full synthetic motorcycle fork oil,
Air valve adaptor and low pressure shock pump.
Disassembling
Remove wheel and disc brake caliper. Too risky to get oil on caliper.
Remove fork or leave it on the bike using the bike stand. Clean excess dirt off.
Take off top knobs of both legs with allen key, don't lose the detent pin and spring. O-ring goes under the ETA knob.
Let air out of the right leg.
It will be less messy to empty oil one leg at a time.
Left Leg (ETA)
Use 21mm socket to unscrew top cap, no need to take the cap off the rod for
oil change.
(Optional-If want to remove the cartridge)
Remove TAS knob below the leg, hold TAS cartridge on left leg from the bottom w/ 12mm wrench while loosening the top with 21mm socket. Oil will drain from bottom hole.
Turn fork upside down and dump out oil, then fully compress fork and drain again. Must fully drain to obtain correct oil level later.
Put some fresh oil in the leg, cycle the rod and stanchion to flush out remaining old oil
Once cleaned, thread top cap back on loosely to prevent oil from further running out
Right Leg (TST)
Remove detent pin and spring under the TST knob.
Use 21mm socket to unscrew top cap, no need to take the cap off the rod for oil change.
(Optional-If want to remove the cap)
Remove small C-clip on the top cap with screw driver, remove top cap.
Cycle the cartridge damper rod and stanchion to get trapped oil out.
Put some fresh oil in the leg, cycle the cartridges, to flush out remaining old oil
Re-assembly
Left Leg (ETA)
Fully compress legs before re-filling with oil.
Volume method: Use a measuring device and pour 140-145cc or 140-145ml into the left leg.
Height method: Spring must be removed. Fully compress stanchion and rod. Remove any zip tie on stanchion.
Fill with clean oil to 45mm from the top edge of the stanchion.
Use straw and clothe pin to measure oil height (hold straw with pin atop of leg to see how much oil goes into straw, plug straw with finger to not lose oil height mark or mark the proper oil height with permanent marker)
Cycle the rod and stanchion to get air bubbles out.
Re-insert the spring into the left leg.
Bolt the left leg top cap, doesn't have to be super tight. Place O-ring over the cap nut. Install ETA cap
Right Leg (TST)
Fill right leg with 40cc or 40ml of oil slowly so it runs past the TST cartridge bladder.
Bolt the right leg top cap, don't make it extremely tight.
Install detent spring and pin. Install TST cap, lining up the air hole with air valve when knob is in lockout position.
Air up the fork.
Trouble Shooting
If fork bottoms out there's not enough oil. If not getting full travel there's too much oil.
If the ETA is not working there is not enough oil.
