Frames
866 Views 4 Replies 5 Participants Last post by  dogonfr
What else do you see on a frame appart from the weight? Is a 1.6 kg frame considered lightweight? Thanks.
1 - 5 of 5 Posts
rigid or full suspension? material steel, aluminum, Ti, carbon fiber? hom many pounds is that?
There are a lot of factors that comes into play when choosing frames.
One of the biggest is the intended use. A freeride frame will be stronger (or tougher) than a crosscountry frame, while the crosscountry frame will be lighter. The angles are different, geometry, if it's a hardtail or a full suspension, materials, built quality, etc..
Also, there are a lot of stuff that makes the final bike light or not, and whether the weight factor it's important or not to a particular rider and intended use. If you're a light rider, and want to do XC races and epic rides, probably weight is an important factor, but if you're a heavier rider, 2 or 4 pounds will not be noticeable, but the stronger materials are more important.
I'm 230 lbs, and my bike should be around 30-32 lbs, but I really like it. It is light compared to some of my friends bikes, and heavy to some other friends bikes.
frames
1.6 kg for a hardtail is a relatively light weight, if you're talking full sus then it's a great weight!
For hardtails and full sus there are many different configurations or designs. There are a few posters who have tried many frames and others like myself who can only recommend what they have. I recommend a hardtail Giant XTC 2003-2006 or as a cheaper alternative this frame Leader LD-515 or 516H looks pretty darn similar to my Giant.
What type of frame are you looking at and what are your requirements?
Ya what he said!! :)
1 - 5 of 5 Posts
