1 - 20 of 21 Posts
Expert Crasher
Astrix Rook (made in the same factory as the EMD). Use the VIP code (HDY15) at Universalcycles.com and get 15% off.
Not really that big!
I know you said $600, but I would give Bitterbrush cycles a call. THey like to do 10% off on frames from time to time. I would spend the extra $75 and get a Salsa Mamasita. I think it retails for $750 so 10% would get you to $675 with carbon stays on a REALLY sweet frame. Offset the extra money spent on the frame by getting a Cane Creek headset instead of a King. Just a thought...
Do you want Steel or Aluminum?
There is a pretty long list of $500 and under frames out there these days.
If the Zion is still available in your size and you want a geared one - that is hard to beat right now. Steel - but still - your stuff should move right over regardless of frame material (except maybe your bottom bracket due to possibly different shell widths between frames).
1 - 20 of 21 Posts
