Go by top tube length...
With your height, you should probably be looking at a Small / 15" frame. That should provide enough clearance vertically. However, remember that each manufacturer uses these measurments in a different way. The crucial measurement to go by is top tube lenght. I suggest you test ride several bikes and base your decision on how they handle, but use for comparison the top tube length.
If you'd like a bit more guidance, check the Santa Cruz website (www.santacruzbikes.com), select any model and go to sizing. They will show their recommended size and stem length (it's probably based on loose averages) for your height.
Nothing beats test riding bikes, though, plus the advise and fit of a good LBS.
