Hi, I found a very fine crack on my 2004 Coiler frame a couple of weeks ago, luckily i spotted it just after I had cleaned it on a weld holding the bottom shock plate on the frame, Kona have said that they will replace the frame under warranty, but I have been told that i may not get the same spec frame back if they have none in stock, has anyone experienced this?, will I get a 2005 spec frame?.
