OK, so I don't know exactly where to post this to get the best cross section of readers, so MODS if it's in the wrong spot, please move it.
OK, so a little back story (I'll be as descriptive and brief as possible).
The Bike is a 2019 Kona Honzo, and the fork is a new PIKE RCT3.
2 days ago I was riding a new skinny feature, and I over corrected and went off of it...my initial plan (after I knew I was screwed), was to just ride off of it...it was only maybe 16-18" drop down, well in my haste I didn't get enough of my body weight moved to the rear...so as you can probably guess, I stuffed the fork and went OTB (had to look funny if anyone saw it...)
I should mention that I'm a heavy rider @ 260 lbs, but I've done FAR dumber things to my old 32mm stanchion Recon forks, and they didn't bend/break, so I'm assuming the burlier PIKE 35mm stanchions are even more robust?
Now, based on the o-ring on the stanchion I didn't bottom out the fork...however I have developed a random click...maybe even a creak at times...I can't duplicate it with any consistency, sometime turning, sometimes not, sometimes over chatter sometimes not...doesn't appear brake related, and it happens sometimes when pedaling, and sometimes just coasting downhill through berms jumps etc..
At first I thought maybe it was the brakes...I'd been planning a wheel swap anyway, so I went ahead and did that (new WTB Asym rims with DT Swiss 350 hubs, and new rotors), that made zero difference.
I thought maybe the headset loosened up? So, I loosened the stem bolts, and checked the top cap tightness (preload??), it was tight, and I felt no free play in the headset.
I don't think it's a bottom bracket noise...it seems more front oriented?
Before the "accident"
there was no noise except maybe a bit of cable/hose flap here and there...so this noise definitely started after the incident...or it's a crazy coincidence...
Can anyone offer some other thoughts on what could make similar noises??
Thanks for reading! Sorry for the long post.
