fram/ shock ahahh answer my question plz
660 Views 14 Replies 11 Participants Last post by  XSL_WiLL
ok i am about to by a kona stink primo and i am wonder were icould get the axle or what ever it is called for the shock that i will buy soon also. as u can see from the picture it is not there. i probley gonna bye a swinger 6way and is there somthing special i will need for the frame to moint this shock. also it does not come with bushings so i could just order thoose from the company right?
1 - 15 of 15 Posts
it's a bolt.. you can easily pick one up at the LBS or local hardware store. just make sure it's a strong bolt
what u mean a "bolt"
a normal frikin bolt derek! i already ttold u there like A BUCK , 1 dollar, numero uno dolaarre.
G
Kona should have the hardware you need and manitou should have the reducers you need to mount that shock to your frame.
yeh but remember to go to the frame spec page and find the standard eye2eye length before you buy
best
yea, you will proabably need new reducers unless the shock is from a similar bike and has them still in it,maybe they will possibly fit. you can get those online though so its not bad. and you can just buy a bolt to go through the hole and mount it
um...youre putting a 3.0 stroke shock onto that? correct me if im wrong, but isnt the shock sizing like 2.5 stroke? i know the regular stinky is 2.3 stroke (2004), so im assuming that since it has 1 more" of travel there might be just a little bit more stroke. I'd reconsider that shock...
Themarsvolta made me laugh! :)
muahaah
niko still has the bolt on his stinky,:) d!ck...
hey i need some advise. I am considering buying a azonic fiend frame. I just want to know if anyone has heard anything good or bad about that frame.
G
Be more specific, and start your own thread.....
You should at least have some idea of how the forum works before you post....
Or at least a brain in your head.
Make as many posts as possible with the least amount of coherence as possible. If there is an oppurtunity to cause confusion or spread misinformation, it must be exploited. Flame out people. Argue about what's best. Argue how big a drop is. Photoshop stuff.
1 - 15 of 15 Posts
