So here's yet one more Dual MCE setup.
After being disappointed with my other smaller setup using the square Ledils I decided to try and do a light using a set of Fraen MR11 sized reflectors.
So I'm posting this thread because there seemed to be quite a few guys building similar lights, just wanted to show the difference between lenses.
I found out that using 2 narrow was like looking down a tunnel so I went and reordered a set of Mediums from Cutter a few weeks ago.I got the Frosted ones-no polished on their website.
I used yet another Hammond case-1455K1201.Using a Maxflex running at 1200ma on high. 6600mah Li-ion 11.1v battery. Cateye mounts.
Heatsink on top of unit is bolted to LED backer,3/16" AL angle.Running the 370lm Neutral WT MCE's from LED Supply. Running 2s2p each LED is running 600ma on high.
I'm not happy with the size of the unit (time for a quad XPG?) but the light it throws out is great
Pictures Below...
2 Narrow Lenses
Medium and narrow
Longer shot-tree is 80ft away
Pictures Below...
2 Narrow Lenses
Medium and narrow
