Fox's Worn Stanchions
14228 Views 45 Replies 20 Participants Last post by  bad mechanic
Who has had worn out stanchions on their Fox forks?
Luckily, I don't have them yet, but as I was working some grease into the surface of one of mine, I noted there was a polishing of the slotted pattern of the 36's bushings into the surface.
Fox claims such things as Enduro seals causing worn stanchions, a point which I counter because every worn out stanchion I've seen from them has the bushing pattern in it early on, and all have had stock seals. Plenty of Fox stanchions wear prematurely without the help of better seals.
If you had a visibly worn stanchion, or one Fox claimed was worn (but didn't look like it), what did it look like? The whole coating gone? Slotted bushing pattern? Factory seals? How long did it take for the stanchion to wear out?
1 - 20 of 46 Posts
A Float came into my possession with worn stanchions. The fork had been ridden for a year by a rather large fellow. The bushing had worn through the because the seals leaked quite a bit of oil, so the work was frequently low, and the guy didn't do regular maintenance. The leaking seal also allowed the oil to be contaminated very quickly, which accelerated the wear. He used stock Fox seals.
This isn't my fork, but the wear pattern looked exactly the same:
With mine, I replaced the stanchion/crown/steerer assembly with a new one from Fox, installed Enduro seals, and then have just kept the fork maintained.
I think, ultimately, it's problem with both the seals allowing the oil to become contaminated, and the stanchion bushing interface not being tight enough. Fox says a little movement is ok, but if you send your fork in to Push, they'll adjust the fit to remove all the slop, which I think is the right way to do it.
Wore out mine with about 6 months of heavy AM riding. After 3 months of riding I noticed it developed some top out play when I pulled wheelies. I called Fox and they said that was normal. Other than that the fork seemed fine then all of a sudden I noticed oil coming out of the seals. After further inspection I noticed the stanchions were very worn with slotted grooves. When I took the fork apart the bushings were worn down to the metal and the oil that was in there was a thick sandy mess. I changed the oil and installed Enduro seals but it could not contain the leaking. The top out play got worse as the fork got more and more messed up. Fox quoted me $350 over the phone to fix it but I did not have the cash so I installed a baby sock around the stanchion to keep the oil out of the brakes and I just kept adding oil. I eventually replaced it with a Totem and then about 6 months after that I sent the 36 in to get fixed. They ended up replacing the whole fork with a brand new 09 for about $375. They also gave me the line that the Enduro seals caused the problem. I told them I installed them after the stanchions were worn.
In Fox's defense I ignored the recommendation to get the bath oil changed frequently. All of my forks recommended about the same amount of maintenance but I've had them last 3 or 4 years w/o any doing any maintenance and not one issue. After having these problems and reading the info on these forums I've realized you really need to keep an eye on your bath oil.
I have a 2005 Fox Vanilla RLC. There's some wear on the lower part of one of the stanchions, spring side, I think, well below the seals. It looks like bushing wear to me. As I recall, the stanchion surface is smooth and polished, but is of a different color than whatever coating is used to cover the stanchion. It's similar to the picture posted by bad mechanic, but the wear area is not quite as large - at least not when I last checked. (Hmm... that was last fall sometime when I changed out the fork oil.)
I've been using Enduro seals in this fork for perhaps three years now. I'm on the second set of Enduro seals now. I don't believe the Enduro seals are in any way responsible for the wear due to the fact that it's significantly below the level of the Enduro seals. It's not worn out yet, though I suppose I ought to check on it again sometime again soon. The fork has seen a lot of use; I'll probably just purchase a new fork when the time comes.
This is classic. I just have to ask.... What did the Fox employee say when you told him the damage occurred before the Enduro seals were installed? Since he was so quick to trash our product I'm sure he immediately apologized...:rolleyes:
Hey Chris! Glad you checked in. I love the passing the buck they do, especially when I've seen forks with bushing marks that indicate anything but seal wear, along with the fact that plenty of Fox stanchions wear while on factory seals (which are garbage, BTW).
At Eurobike, Fox's reps immediately stopped me while I was explaining my opinion of their seals, which are really not that effective to begin with. I like the lube to stay inside and not pick up dirt and bring it into the fork on compression. The rep also offered to sell me a Talas III cart when I spoke about how I might need to rebuild mine, and he also tried to sell me a new RC2 cart (the 09 model when I asked how different it is and if they would be willing to let me test one out and publish a review on this site if they were so confident). Basically, I was offered to buy a complete 09 36 at that point.
On another note, maybe Darren will chime in, but some months ago, he announced a project with Turner bushings and a different material. I asked about the possibility of fork bushings being made of a better and more wear-resistant material. I don't know if there has been further development, but I'd love to try something out that helps improve my fork's durability. These things are starting to cost more than medical equipment.
*I also read my wording above and it was strange in the OP. My stanchions aren't worn, but at certain angles, when greased, light reflects a polished imprint of the bushing's slotting pattern.
My 2004 Vanilla 130 RLC started developing grooves on the front, coil spring side within a year of use. Back then I observed:
1) The groove started about 2cm above the seal (when static), and expanded down into the seal. At a glance, it clearly meant something below the seal (sure could’ve been the seal) was causing this.
2) Taking the fork apart for a regular oil change, I could clearly tell that the bushing (white collar) was worn, where the stanchion has been “rubbed” on. Exact spot.
Therefore, my conclusion was that this has been caused by the slop in the Fox bushing.
Shortly after I noticed this (about a year into using it), I switched to Enduro seals. Yes I noticed the wear before I put the Enduro seals in. I’m happy with Enduro seals – even with the groove, the leakage is still manageable because of the fit of the Enduro seals – it actually seals the fork! I figured I would ride this fork to its death anyway. I would hope that I will have enough $ to buy a new fork by 2014, and by then it will be a “vintage” and I can sell to VRC folks for $200. With grooves and all:thumbsup:
Despite this issue, I love Vanilla, hands down. Easily serviceable and works as expected every time. Fox customer service has been very good too, although they sound like they are quick to put the blame down on other things:) I just wished that they used a better (more fit) bushings. But then no one buys new forks...
My 08 32 talas rlc had the same wear on the spring side after 6 months use
there was no oil when i took it apart
my 08 36 float rc2 started leaking after 3 months took it apart and there was very little oil
installed enduros and its been great since
servicing the Fox forks are a must how much depends on the amount of use and conditions i do mine every 2 months or so
OIL is cheap
My 05 F100 has this last time I took it apart. It also had a lot of bushing slop. It was a little low on oil for a while, but even after adding oil the problem only got worse. Now part of the stanchions look like bad mechanic's photos, worn straight to the bare metal.
Damn, that's crazy. It's a result of the way they designed/produced them, but it's still crazy. I'm rocking a 66 from 2006 that I've beat to hell every single year (4 seasons now), have a Monster T here from 1999, and you just don't see that kind of wear on something that is well lubricated with proper bushings. It's kind of crazy how certain parts of the fox forks seem so well thought out and designed (dampers) while other parts are absolutely laughable (seals, this issue of wearing down the stanchions).
Didn't RS learn this lesson back in the day when they used metal bushings?
Early Bombers had what I thought the best bushing design. It was thin shelled, rolled to shape and very long. Easy to install or remove as it was retained by the seals retaining clip.
PK
That was a good design, no doubt.
Now bushings are easily available, but how does one improvise a tool to remove them? I was thinking of making something out of two allen keys with extensions to pull them out, but I don't know if it would work. I could also try to make something to fit into a locking extension bar.
Take a washer which is the same diameter as the bushings. Grind flats into the side of the washer on opposite sides so it looks like this:
Put a washer on a long threaded rod, and keep it from falling off the end with nylock nut.
Take the fork's lower and angle the washer so it can slide past the bushing (the reason for the flat sides) and then get the washer flat and pull it up against the bushing's underside. Once there you can either use a slide hammer to pop the bushing out, or put another washer and nut on the threaded rod and tighten it down on the top of the lower and pull the bushing out like that.
Cool. Now how about the DIY bushing insertion.
You guys are too smart.
Nice. I was going to improvise some pryhooks that could be swiveled and locked into place once past the bushing.
This is a little more involved.
There are a couple ways to do it. The route I went was taking the old stanchion and JB Welding several old bushing onto it, one bushing's height from the bottom. I used fine sandpaper to knock off the slick coating on the inside of the bushing and the outside of the stanchion, and then used hose clamps on the bushings for 24 hours while the JB Weld set. I then drilled holes through right through all bushings, and glued metal rods in place, and ground their ends flat with the bushings. It's probably overkill, but it works. I then used sandpaper to slightly reduce the diameter of the bushings.
Before extracting the top bushing, I'll place my installation tool in the lower and mark the top edge of the lower with a Sharpie on my installation tool. I then remove the top bushing. Then I repeat the above procedure with the lower bushing. Then to install, I put the new bushing on the installation tool and set it at the correct height using the Sharpie mark on the tool, and then the same for the top bushing.
This talk forced me to do my periodic seal cleaning and relubing. The fork still has oil, so that's good. I added a slick teflon-containing grease, this time to the stanchions under the oil seal, as well as between the dust and oil seal (as normal). I feel adding a slick grease (not a sticky one like Prep M) helps a lot with any stiction one might have and helps preserve the stanchions, but I'll only know in time.
I added the grease some months ago to the seals, and it was still lubing the stanchion surfaces to this point, so it's not terrible, but I'm still worried about wearing through the bushings and knowing when it's too late.
I have a bottle of Liqui-Moly's MoS2 Moly containing motor oil. Makes me wonder if I can use that for the bath. Probably plain motor oil would work better than suspension oil to begin with. I haven't done it yet only because I was worried about more friction and accelerated wear because I don't know the size and characteristics of the MOS2
It's generally not a good idea to slap grease onto the stanchions since the oil is going to wash it away quickly, and then you won't know how it will be affecting the characteristic of the oil.
Don't use motor oil, it's too heavy.
I've heard that using RockShox seals in place of Fox seals works well and lasts a lot longer. Does anyone have any experience, or should I just change over to Enduro instead?
1 - 20 of 46 Posts
