1 - 17 of 17 Posts
dude both are good choices but...
if you want to put a fork on you8r bike that is sooooooooooooooooooo much more fly than either of those just put on the dt swiss
it will make a bike that is pimp soooooooooooo fly
if you are set on eiyther of the other two
i have 2 of the foxes an the lockout broke on both
i dont know about any issues with the reba
cheers
Fo' Bidniz in da haus
race bike as in XC race? how much do you weigh? Both forks are fine...i just put a supposed POS 2008 Reba on a bike and I have no worries about it as I am only 175 lbs and its for XC duty. Unless you are a typical 29er phat azz and/or plan to truly do more than XC duty it dont matter none. The poploc is a sweet feature IMHO if you like to stand as well. Of course the 2009 Reba makes this less of a debate but even 2008s are fine for XC duty as far as i am concerned
Pixie Dust Addict
I have an '07 Reba that is perfectly well suited for XC riding. Granted, that's with a stiff wheel (I9) and axle (DT RWS). The damping is sufficient and can be improved with a little PUSH love. As of today, I have Reba Team 120 with the 20mm axle on the way. Can't wait to compare the two.
Both are fantastic forks, but might I suggest you roll on over to JensonUSA and pcik up one of the last manitou Minute 100s with TA for $268. It'll save you a ton of cash which you can then spend on other components and it'll be super stiff.
sloppy second said:
Building a Redline D660 race bike next season am pretty confused on which fork to purchase the reba race or team or the fox f 29 100. Please help me finish my bike.
The Other Dude
I was dead set on swapping my Reba SL on my stumpjumper out for a fox, i have just always been a fox shox guy, but i have to say i love the Reba, i weigh in at 175lbs and its i just a great fork, i actually wish my superfly came with reba instead of the fox, if it wasent a G2 fork, i would have a Reba on it.
:lol: :smilewinkgrin:
I'm glad I'm not the only one who noticed this. However; I'm 6'2" 165Ibs so the stereotype doesn't always ring true. Heck if I were over 200Ibs a 26 inch wheeled bike just wouldn't make sense.
2 F29's and no problems here. an 80 and a 100. never had an issue with the lockout either. I also have the DT 9mm Thru Bolt on both wheelsets so that might also add stability to the setup. Can't argue with a Fox ride.
I like bikes
Wtf?????
i just put a supposed POS 2008 Reba on a bike and I have no worries\
Did you just bonk your head or hitting the eggnog early.:p
I just recently changed from an 08 Manitou Minute 29 to a Fox F29RLC , wow what a difference. The Fox soaks up the trail like its nothing, plants in the corners , and softens landings.. I ride SS and this fork has very little bob.. I have ridden Reba on other bikes though a nice fork I still prefer the Fox.. Advantage on a reba 29 I guess would be the remote lock out..
1 - 17 of 17 Posts
