1 - 3 of 3 Posts
Hi, I'm trying to set the sag on a Vanilla Shox. Its way too much. The preload ring has been moved quite a bit. Do I keep turning the ring and spring counterclock wise until i get the right sag?
No more than 2 full turns from when it first, firmly contatcts the spring, if you need more than 2 full turns of preload you need to go up in spring rate. If you need help on calculating spring rate google "TFT tuned spring rate calculator", then plug in your travel, stroke, and weight and that will get you in the ballpark of the correct spring rate.
1 - 3 of 3 Posts
