that can take awhile asking something. You can always call them and your LBS. They should fit on your bike no problem.(i think)mxrider489 said:I've also seen Big Hits with DHX's and I'm pretty sure it can be done. On the specialized sight there is a help section in which you can ask questions and a specialized rep will answer you. There are many questions reguarding different parts fitting The Big Hit and I'm sure they could help you with your question. I'm sure you already did it but there are also multiple pictures of Big Hits on pinkbike with DHX's.
Not doubting you, but have you taken the spring off and compressed the suspension to be sure that the blue adjuster knob doesn't contact the frame on full compression? I beleive this is the problem that the others were talking about, I've seen it happen. Do you think it would be too much to ask for pics of this being done, pleez?weird terry said:The DHX fits on my '01.
Yes, I checked it with the spring off. If the bumper is fully compressed and the shock is completely bottomed out, the cap to the air fitting might hit the frame. I'm not worried about it.red5 said:Not doubting you, but have you taken the spring off and compressed the suspension to be sure that the blue adjuster knob doesn't contact the frame on full compression? I beleive this is the problem that the others were talking about, I've seen it happen. Do you think it would be too much to ask for pics of this being done, pleez?![]()
How much damage could that cause and what size shock is that?weird terry said:Yes, I checked it with the spring off. If the bumper is fully compressed and the shock is completely bottomed out, the cap to the air fitting might hit the frame. I'm not worried about it.
Next time I swap springs, I'll try to remember to take some pics.
Could possibly damage the shock as well as dent the frame. Shock size is 8.75 x 2.75.MX 887 said:How much damage could that cause and what size shock is that?
Thats not good. How could he not be worried.red5 said:Could possibly damage the shock as well as dent the frame. Shock size is 8.75 x 2.75.
I'm not worried for a couple of reasons. I don't do big jumps or drops so I'll probably never bottom out the shock plus the shock has an adjustable bottom out level.MX 887 said:Thats not good. How could he not be worried.
I pmed ya some questions
