Neu5p3ed said:
Question for you again.
Seems like you've worked with many, from your reply. Now is this a common problem and how long does a shock usually go before this seal blowing again? Am I going to have to do this every year?
Honestly, this type failure has just recently started. I'm guessing it has taken that long for the "O"rings to soften from the fluid and fail.
My speculation is that with Fox now using Silkolene fluids the Silkolene is the culprit. It is pretty powerful stuff, but also a great fluid for rear dampers.
I have used Silkolene in many Moto and Bicycle components over the years. Sometimes crazy thing like this happened.
As for will it need to be done each year, well, if you ride the bike any amount of miles, you should have the rear damper serviced twice per year. They hold almost no fluid and they see a lot of fluid breakdown.
In addition, and this happened just a couple of weeks ago, a guy wanted his leaky fork and shock rebuilt. Without even taking them apart, the wear from grit was so severe I handed them back and told him they were junk. Had he done routine services, he may have been fine, but he just kept riding until he killed them.
PK
