I've got a 2004 Fox RL rear shock. It's got roughly 700 miles on it, it's in a Santa Cruz Superlight. My usual setup is with 105 lbs in the shock. My problem is, on cold rides (colder than 35 degrees) air pressure is leaking from the main chamber to the negative air spring side and pulling the shock down. Pumping the shock to 250 lbs doesn't cure this condition. I just performed a total seal rebuild (all seals, bearings, rings...everything) and service of the shock using a brand new rebuild kit from Fox and Fox Float fluid (previously I was using Slick Honey) and the problem still happened. I do have a habit of "liberally" applying Float fluid, leaving extra above the body seal and extra in the Air Sleeve above the Air Sleeve bearing.
Any suggestions on what I'm doing wrong or something I can do before each cold ride to prevent this? I'm getting tired of riding with a partially stuck down shock and then having to "pop" off the air sleeve after the ride.
Thx.
Thx.
