If you plan on getting the new Fox roller bearing kit 8x30mm for your rear coil shock (DHX2 coil), be aware that if you have to change spring weight, you will need to remove the bearing kit. To remove these pressed in bearings, you will need a special bearing removal tool from Fox. That tool is $110, and good luck finding it in stock! The spring will NOT fit over the bearing kit. Also, if installing the bearing kit, make sure you put on the spring, and all corresponding hardware first. Kind of a huge pain in the a$$ if you ask me. Thought I would warn you guys.
