1 - 2 of 2 Posts
Hey folks. I'm considering the after market Inertia valve upgrade for my Float RLC 80. My question is this. My fork came as a 80mm. Included with it was a spacer to expand the travel from 80 - 100mm. If were to go with the upgrade, could I opt for the 100mm set-up and use the spacer to extend the fork's travel?? I'm feeling like this is a dumb question, but obviously want to make sure it'll work.
Pivoteer
Get the 100MM
You can get the f100x cartridge from Fox for $150. If you get the 80mm , it cannot be extended to 100mm When I upgraded mine, I got the 100mm cartridge and cut it to 80mm for my Singlespeed. Now I am having a new frame built around 100mm, so I can remove the spacer and be on my way.
1 - 2 of 2 Posts
