Just to clear things up.
The way it works is when you place an order for either a Mojo or HD with an Ibis build kit, and you are ordering a Fox fork, it will not come with the Kashima coating from Ibis.
You can ask your local bike shop to delete the Fork from the kit and then add on a Fox fork with the Kashima coating which I assume would come from Fox directly.
I asked the bike shop I am dealing with what the difference would be, and was told around $500, which I thought was definitely not worth it.
If you order a Fox Talas 32 fork with an Ibis build kit, it will come with 2-position travel adjustability set at 130 and 150mm, which is unique to Ibis.
The Talas 32 from Fox comes with a 2-position TALAS system that instantly changes travel between 150-120 mm, or 140-110 mm.
If you order a Fox Talas 36 Fork with a build kit, it will come with the same travel settings as from Fox, 2-position travel adjustability set at 120 and 160 mm.
Once again, Fox forks in an Ibis build kit do not come with the Kashima coating.
