fox has parts drawings and exploded views. 6-32
Did you ever attempt a syringe bleed? did it work? ThanksSeriously ... What are the thread specs for the 2019 Float X2 bleed port? I'd love to do a syringe bleed when I open it up, but I can't find any reliable info online on what type of adapter I need.
Yes, and it was a disaster. Well, the bleed itself wasn't a disaster. It just didn't work. But, the whole process was a disaster.Did you ever attempt a syringe bleed? did it work? Thanks
Lol. I missed this. Looks exactly like what I was looking for. Thanks!![]()
Bolt-On Pressure Fitting
Includes brass pressure fitting, nut and fibre washer (nuton #241 only). Easily mounted on muffler or crankcase by drilling and tapping correct size hole or using the included nut to secure (#241 only).1/pkg Weight: #241 - 1 gram/assembly #539 - 1 gram/assembly #540 - 1 gram/assembly Made in USAwww.dubro.com
Thanks for your reply! I just meant in theory, if you had that adaptor could you just connect that to a syringe full of oil and bleed a shock, or do you think you need to have an actual fill machine?Lol. I missed this. Looks exactly like what I was looking for. Thanks!
I have a vague recollection of seeing one of the guys on Fox Dialed doing it with a syringe. That's why I started down this path.Thanks for your reply! I just meant in theory, if you had that adaptor could you just connect that to a syringe full of oil and bleed a shock, or do you think you need to have an actual fill machine?
You can but you'll be there a long time. If you're doing a syringe bleed you start with filling the shock by hand as much as possible during assembly and use the syringe to displace final air bubbles.Thanks for your reply! I just meant in theory, if you had that adaptor could you just connect that to a syringe full of oil and bleed a shock, or do you think you need to have an actual fill machine?
Do you know what’s the tubing ID it takes on the non-threaded end?![]()
Is it preferred to bleed from the damper body port over the reservoir piston (using a vacuum machine)? I guess setting IFP depth will be just a little more tricky or messy.You can but you'll be there a long time. If you're doing a syringe bleed you start with filling the shock by hand as much as possible during assembly and use the syringe to displace final air bubbles.
If you're doing a vacuum bleed the shock goes together dry and those can take a huge number of vacuum and fill cycles to get all the air out.
Vacuum bleeding takes the air out of the oil (about 8% by volume at room temp/pressure). This means the shock can absorb a lot of air before it gets slurpy. Where a manual bleed is relying on more IFP pressure to keep air bubbles dissolved.
Dubro DUB-241
Thread Pitch #6-32
Total L: 12.6 mm
Thread L: 4.45 mm
Thread OD Max 3.45 mm
Barb L: 6.1 mm
Barb OD Min: 3 mm
Barb OD Max: 4.2 mm
I found this RC engine brass fitting online and a local hobby shop had them in stock. Seems like they're available world-wide.
I adapted it to M5x0.8 Rockshox thread by brazing it to 2 fittings from an old generic bleed kit. Looks a bit rough but sealed tight and my DHX2 has the best bleed I've ever been able to give it.
Cost inc delivery,
$10 AUD - 2x DUB-241
vs
$125 AUD - Fox 803-00-463 - AirNShox
$90 AUD - Anso Adapter
