1 - 1 of 1 Posts
prob a total noob question but, i need help with the high speed and low speed compression. i understand the concept of high speed as it helps with the quick hits the fork takes on the trail and the low speed is more for drops and such. so does turning the knobs to the plus side make it more sensitive or less. i have set them both in the middle setting (16 clicks/ 2 so 8 clicks). just wondering what would be a good base to start with or just knowing the going up click makes it more or less sensitive would help a lot.
yes i did some searching on the web but couldn't really find anything that helps.
1 - 1 of 1 Posts
