1 - 6 of 6 Posts
Banned
I have a yeti 575 with the rear shock being a fox float rp23. I tried putting air into the shock but it seems to leak out. I cantg figure out how to keepm the pressure in the shock. I used a regular tire pump (for cars) to put a little air in, but when I put a tire gauge on the air leaks out. Please help
Super Moderator
you will need a shock pump (low volume high pressure pump)
also..it is likely that the air you are hearing is mostly coming out of the pressurized hose of the pump..not from the shock
Banned
Discussion Starter · #5 ·
Thank you for the answer and moving me to the correct spot
1 - 6 of 6 Posts
