1 - 2 of 2 Posts
I have a Cannondale Jekyll 400, which comes with the basic fox float. What is a good PSI to keep it at? I do like it to be a little lose to soften the ride up. I've been told weight plus 25, but that is only 205 PSI.
psi
if you want a plush ride, then 90% of your weight. if you want a stiff ride (lots of climbing, ect...) then your weight plus 10lbs. consider getting your fox pushed by darren at push (www.pushindustries.com ) it will make a huge difference
Good Luck :D
1 - 2 of 2 Posts
