My 2013 Fox Float CTD Kashima rear shock is slowly leaking holding air. I decided to rebuild it with a seal kit but, of course, I am having a problem:madman:
I pulled out the top (apparently called islet) o ring. This is the O ring that sits up high by the lever portion of the shock.
The O ring is significantly larger than the O ring that is supplied in the kit. Has there been a change in this O ring?
The O ring was sitting in a thin crevice just above the threads. The O-ring supplied in the kit is too small to lay flush into this.
To make matters worse, I can't get the old O-ring back in the little area I pulled it out of since it is so narrow.
