1 - 20 of 42 Posts
I'm seriously considering swapping to a Float CTD rear shock, on my 2013 Spark 900 Premium and I would like to get the remote shock variant .
1) Does the 2013 Scott Twinloc lever (ie the Twinloc lever with longer levers and configured for a DT Nude2) work with CTD remote set-up - is the cable pull the same between Trail/Traction-Mode and Climb/Lok-out?
2) Which Velocity/Rebound/Boost Valve tune settings are other users running?
Discussion Starter · #3 ·
Yes, I've been running a CTD rear shock since May and the difference is night and day, compared to the Nude 2.
The twinloc lever operates the damping modes perfectly, so no problems there.
I bought the shock on eBay and then had Fox UK custom tune it for me. I'm running:
Rebound Tune - M
Compression Tune - F
Climb Tune - F
Boost Valve pressure - 250psi
1 aircan volume spacer
I'm 6'/155Ibs and ride cross country, and the shock tune is absolutely spot on for me.
Thank you so much! My fork is at fox getting the fit damper, 2015 seal heads and kashima stanchions. I've been talking to them, and fox thinks there might be some clearance issues with their rear shock on my 2013 930 frame. I'm assuming our frames are identical dimensionally. Is your shock a 6.5 x 1.5? Can you a pic of your rear shock set up? Thanks.
how did you make out?
I had everything done last year, and it was worth it! Bike feels competely different, much more active yet effecient when I lock it out. BUUUUUTTT, about 2 weeks ago, decended in full open, got to the bottom, and went to trail and then to climb mode, and the rear would not firm up. So its actually (rear shock) at Fox right now. THe only thing different Im going to do this round is invert the rear shock, that way I will have clearence for my water bottle. Actually we got it back and mounted in that position and it looked fine and the cable routing was fine, but then we realized it was still not firming up, so it went back. In the pic besides the fork and shock, I also converted to 1 x 10.
Tire Wheel Bicycle wheel rim Mode of transport Automotive tire
well I got my shock back and it was a totally different shock and not in a good way (for me). They completely firmed it up. The Decend was like the trail was before, and trail and climb were pretty much the same-FIRM. Called service and they said the wires got crossed and thought I wanted it firmed up versus fixed. So its going back for a third round. I did ride it before going back and climbing in trail was awesome, but overrall I wanted more plushness out of it. I did install it inverted and that was awesome as I have tons of clearance for my water bottle. Ill let you all know what happens. Ill try to email and find out what tune they did exactly this last time that was super firm.
I believe he said it was around 135psi boost, and it has Med comp, and Med Climb
It says CP2P on the decal.
Im wondering if I should just send it back to the retailer and buy one straight from fox that everything is correct on?
1 - 20 of 42 Posts
