1 - 2 of 2 Posts
Hi guys, I run a Fox Float CTD on my Merida One Sixty. I'm about 200 lbs. I set it to about 20% sag. But it feels like it is extremely soft, if I push down hard I can almost bottom it out, I would be using around 85% of the travel just by pushing down. Any other people had this problem? Any help would be great thanks
Run a low volume air sleeve if equipped w/ a HV. If you already have a LV sleeve you can use volume reducing spacers depending on the shock configuration. If after air spring volume reduction, you are still not satisfied, consider a custom shock tune.
1 - 2 of 2 Posts
