Hello,
I have a bike equipped with a Fox Float 150RL.
Since I am kind of a lightweight, (150lbs) I don't need to add too much air to the fork to reach the desired sag. When I add the amount of air that Fox specifies, I won't come close to the 25% of sag I would like to have. I ended up with adding around 55 psi, but then I experience excessive brake dive. Since this particular model lacks compression adjustment, I was wondering if there's anything I can do to prevent this. I saw that for the open bath models, there is no such thing as a cartridge with compression adjustment. Is it possible to just swap the current cartridge with a FIT RLC one or it isn't that easy?
Regards
Regards
